My legacy rolled!
Goddoll
My legacy rolled!
Post by Goddoll »
So, I was going down the street thinking "this old 94 will make it to 300k easy", and for absolutely no good reason, the thing threw a tantrum, and kicked left into a ditch, then rolled over.
I didn't get much of a chance to look at the damage, but it started, and no oil in the air, so I'm hoping it will still run.
Anyway, if it doesn't...
Imma need a new Subaru. There's a 2003 outback L.L Bean with a bad manual in my area, in my price range.
How hard would it be to swap out the automatic transmission in the 94?
Edit: turns out that the outback is an automatic as well.
Sent from my SM-G930V using Tapatalk
Re: My legacy rolled!
Are you wanting to swap the automatic transmission into a manual transmission car?
Due to the additional electronics and wiring it's going to be a lot more difficult, if not cost prohibitive especially since the model difference is substantial.
Goddoll
Post by Goddoll »
Legacy777 wrote:Are you wanting to swap the automatic transmission into a manual transmission car?
Its actually automatic in both. Does that make a difference?
So you're wanting to take the automatic from your 94 and put it into the 03?
If so, there a difference in transmissions. The 94 is a phase 1 4EAT while the 03 is a phase 2. The final gear ratio is the different. The 94 would have a final drive ratio of 3.90 and the 03 Outback, according to this site has a 4.44 final drive ratio.
Short answer, no you can't swap them.
redneck_impreza
Post by redneck_impreza »
You actually could swap them as long as you also swap the differential from your 94 into the outback
Pntaste4evr99
Winestone Cowboy
Post by Pntaste4evr99 »
Or just buy a diff subaru in your price range??? Be done....
94 Winestone SS 5MT Rob 550 20g. (Pickle)
Original WA car with 460k miles and climbing
