Robtune 550cc
JimBos Legacy
Robtune 550cc
Post by JimBos Legacy »
If I were to run 550cc Top feed injectors, instead of running the adapters for the yellow top side feed injectors, would the 550 tune still work? I found some 550cc top feed injectors online awhile searching around
JimBo
1992 JDM Subaru Legacy GT wagon
Re: Robtune 550cc
I don't think the injector latency (dead) times are going to be the same between the side & top feeds. If you can find that information about both types of injectors you could clarify that.
Are you planning on using a different intake manifold? If not I think fitting the top feeds on there would take a lot of work.
JimBos Legacy
Re: Robtune 550cc
Legacy777 wrote:I don't think the injector latency (dead) times are going to be the same between the side & top feeds. If you can find that information about both types of injectors you could clarify that.
I read somewhere that too feeds would work on the stock fuel rails without the adapters. Maybe I read wrong. Phase 2 adapters seem to more commonly available then I thought. Probably would end up being easier to get the yellow tops and adapters.
JimBo
Re: Robtune 550cc
Top feeds will not work on the first gen Legacy fuel rails.
What adapters are you thinking of using?
JimBos Legacy
Re: Robtune 550cc
Legacy777 wrote:Top feeds will not work on the first gen Legacy fuel rails.
One of the kits I found is by a company called Deatschwerks, haven’t looked around the fourms to see if any one else has used them.
JimBo
Re: Robtune 550cc
That kit is for the Newer Subaru manifolds. I don't know if they would be a direct fitment on our cars without some work.
JimBos Legacy
Re: Robtune 550cc
Legacy777 wrote:That kit is for the Newer Subaru manifolds. I don't know if they would be a direct fitment on our cars without some work.
I’ll take a look at the injectors and see if it looks like it’ll bolt up
JimBo
carfreak85
Re: Robtune 550cc
Post by carfreak85 »
JimBos Legacy wrote:If I were to run 550cc Top feed injectors, instead of running the adapters for the yellow top side feed injectors, would the 550 tune still work? I found some 550cc top feed injectors online awhile searching around.
The tune was developed with a specific set of hardware in mind. Deviating from that exact list of parts is a gamble I would not be interested in taking.
1975 Superstar Wagon
1984 GL-10 Turbo-Traction Wagon & Hardtop
1987 & '87.5 RX coupes
1987 RX Type-RA
2002 WRX sedan
2019 Outback 2.5i Limited
JimBos Legacy
Re: Robtune 550cc
That’s why I’m thinking I’m going to go with Robs adapters that he sells, he mentions that deatschwerks work aswell, but are a bit more pricy.
JimBo
Re: Robtune 550cc
What intake manifold do you currently have, Jimbo?
JimBos Legacy
Re: Robtune 550cc
mike-tracy wrote:What intake manifold do you currently have, Jimbo?
I don’t have the exact part number, but it’s the stock manifold on a V1 Ej20G
JimBo
Re: Robtune 550cc
Ahh. all you need to do to use phase 2 sidefeeds is ej25d (all years, 96-99) rails. I know you were talking about retrofitting top feeds, but Rob's conversion kit does the same thing as using ej25d rails on an ej20g manifold.
JimBos Legacy
Re: Robtune 550cc
mike-tracy wrote:Ahh. all you need to do to use phase 2 sidefeeds is ej25d (all years, 96-99) rails. I know you were talking about retrofitting top feeds, but Rob's conversion kit does the same thing as using ej25d rails on an ej20g manifold.
Gotcha, so it’d probably just be easiest to run robs adapters. I can’t seem to find the ej25d rails anywhere, but maybe I can find them at a junk yard somewhere around here
JimBo
