Does anybody know if this would be a direct swap with 92 rhd legacy? Or what it would take to make this swap? Thanks
https://www.ebay.com/itm/JDM-Subaru-Imp ... SwMYRaXjFa
GC8 cluster in 92 rhd legacy
JimBos Legacy
JimBo
1992 JDM Subaru Legacy GT wagon
Re: GC8 cluster in 92 rhd legacy
Physically it's not a direct swap, and plugwise it's not either. You should contact Iwire to see what's involved in rewiring it, I'll bet with Impreza cluster plugs you could repin it to work.
If I were going to do it, I'd take everything out of the legacy cluster's case and put the guts of the GC cluster in there. You'd probably have to use a flat piece of plastic with the appropriately cut holes so it doesn't look like ass.
The one you linked has a mechanical speedo gear receiver, that's the one you want.
