resonator size inlet
wondering what size inlet and outlet are. it looks like 3"-3.5"?? and has anyone ever tried to use pcv pipe instead of metal.
Re: resonator size inlet
You might search for the coffee cup mod. Used to be the thing to do to replace the resonator. You may get better results doing a google search.
arse_sidewards
You've posted this question several times. What is the broader project that's going on here?
Yes, PVC is fine for air intake use though it might get a little soft if being fed 300deg turbo air.
1992 FWD MT wagon, 1994 AWD AT wagon
Locking this thread to help keep all conversations in one spot.
Please continue with the other one
viewtopic.php?t=56951
