Hello guys!
Car - Legacy BJF, USDM
I have a heater issue - fan is working only in Max A/C mode, in others - keeping silent.
1. I've changed the resistor (100% working) - still the same
2. I've changed the heater relay - still the same
On heater fan connector "plus"/power - only when max a/c is turned on. In other modes - no power.
Please help where to dig to find the problem, maybe someone has electrical schemes for USDM BJF?
Heater issue, Legacy BJF
arse_sidewards
Re: Heater issue, Legacy BJF
Timely thread. Mine works on all the vent modes but the fan just turns off if I set it to high. Guess I should actually get around to looking at the diagram.
1992 FWD MT wagon, 1994 AWD AT wagon
arse_sidewards
Postimg link to the wiring diagram:
Can you please send the whole picture of this page? Need to know where red yellow wire goes from the relay
arse_sidewards
You may want to review this thread.
It could be bad solder joints on the HVAC control board. You can remove it and resolder
viewtopic.php?f=10&t=1142
Thanks, Josh!
Okay, will do it, thanks! Hope it will help!
