wheel vibration at 60+mph
Locked
moyama99@hotmail.com
Post by moyama99@hotmail.com »
anyone out there have a solution for this?
notes:
-car is a 1991 soob legacy wgn AWD...purchased two months ago. only
78K miles!
-vibration felt in steering wheel at speeds of 60+mph...vibration has
been felt since purchase. assumption was tires needed balancing
-just added 4 brand new tires
-wheels have been balanced 2X
-new inner\outer CV boots (right side)...mechanic check'd CV joints =
look'd ok. no "clicking" when cranking the wheel side to side.
mechanic suspects worn u joint in transaxle. he showed the amount of
play when the car was on the lift. it is noticable but seems weird
that it would cause the vibration.
what do you guys think?
Rod
Post by Rod »
Have you checked the brake discs, they may require machining.
Have you had the car wheel aligned, front and back, since the new tyres? U
joint in trans, what is the 'U' joint? Do you mean where the propellor
shafts meet in the middle, centre bearing? If this was out the vibration
would be felt through the car, not the steering wheel.
My old Liberty had 240,000km on the clock when i sold it, never had trouble
with worn trans. parts. Just the usual, CV boots/joints, brake discs. Never
had vibration prob's.
Regards, Rod
----- Original Message -----
To: <BC-BFLegacyWorks@yahoogroups.com>
Sent: Sunday, June 24, 2001 6:36 PM
Subject: [BC-BFLegacyWorks] wheel vibration at 60+mph
> notes:
> 78K miles!
Dave C
Post by Dave C »
Even though everthing's been balanced, at speed you can have problems
with the brake discs that can make it feel like the wheels are out of
balance. This can be amplified by worn struts as well.
The transmission is not at all a likely candidate for problems.
> notes:
> 78K miles!
has
of
daniel.wilson@db.co.nz
Post by daniel.wilson@db.co.nz »
I dissagree. The drive axles are the second weakest part of the
Subaru drive train and are very likely to break or bend.
Subaru are aware of vibration problems with auto trans Subaru
Legacy's, this problem is due to the drive axles used for the auto
trans models. The fix is to replace the axles with manual trans front
axles.
Dan
problems
of
> > notes:
only
> > 78K miles!
> has
joints
> of
weird
Dave C
Post by Dave C »
That's true. I wasn't saying the axles weren't to blame, but that
the transmission wasn't to fault.
front
> axles.
> Dan
> problems
out
> of
> > > notes:
> only
> > > 78K miles!
60+mph...vibration
> > has
> joints
amount
> > of
> weird
Rod
Post by Rod »
process of ellimination.... starting with the more obvious lost cost repairs
first..... have the discs machined first...... have the car wheel
aligned....and then see....
Rod
Sent: Monday, June 25, 2001 2:44 AM
Subject: [BC-BFLegacyWorks] Re: wheel vibration at 60+mph
> > notes:
> > 78K miles!
> has
> of
Sorry I shouldn't have had dissagree on that e-mail.
Dan
auto
> front
> > axles.
> > Dan
> > problems
> out
> > of
> > > > notes:
ago.
> > only
> > > > 78K miles!
> 60+mph...vibration
> > > has
balancing
> > joints
> amount
> > > of
> > weird
thanks for all the feedback guys!
I'm going to rotate the front wheels to the rear this week. just in
case one of the rims are warped, etc...follow'd by the suggestions in
the thread.
another ques:
how long are the stock struts good for?
I was thinking about dave's comments re: worn struts. the car does
well with the "rebound" test...no excessive bouncing when pushed, but
the front right side does sound kinda nasty.
cost repairs
> Rod
> From: "Dave C" <legacycentral@y...>
> To: <BC-BFLegacyWorks@y...>
problems
out of
> > > notes:
only
> > > 78K miles!
60+mph...vibration
> > has
joints
amount
> > of
weird
> > Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Dave C
Post by Dave C »
It's a combination of miles and time. Your mileage is about right
and the time is well past.
The KYB GR2 is a good, cheap replacement. The AGX is adjustable and
about %20 more.
The car will drive much better with new struts.
in
> the thread.
> another ques:
but
> cost repairs
> > Rod
> problems
> out of
> > > > notes:
ago.
> only
> > > > 78K miles!
> 60+mph...vibration
> > > has
balancing
> joints
> amount
> > > of
> weird
Locked
