Hmm, You should find lots of info on Transmissions here. I have mine apart
now having blown 1st and 2nd. The scyncros are about $60 (cdn) or so. I
think they are cheap insurance. You will need several tools to do it. Once
you get the transmission out and removed the oil, you have to remove the
rear box, this contains the center diff. Then remove the bolts holding the
two halfs of the case together. When you are ready to open it up, you need
to lay it on its left side (looking at it from the tail forward to the bell
housing) and the case opens up towards you. This is a far as I have gotten.
I did investigations and found out what was wrong on my transmission when
another good transmission appeared for sale for the same price and fixing
mine. I know I was lucky. The transmission has turned into a
after-race-season-to-be-completed project. I was going to order the parts
and give the transmission to a local shop to replace the parts and
re-assemble it. I didnt want to get shafted by any transmission shop.
Mark
www.rrunracing.com
At 02:19 PM 07/28/2001 +0000, you wrote:
>When my air conditioner went it sounded like a lawnmower with a rock in it.
>I had to have the compressor replaced. Apparently the stock A/C compressor
>is not one of Subaru's strong suits.
>On your intermitent sunroof and power mirrors operation, I would look for
>either a bad ground, or a power supply relay / breaker / fuse that is not
>operating consistently. One test would be to check if the power mirror and
>the sunroof fail at the same time or independently of each other. If it is
>simultaneously, perhaps there is a common connection point. Check you
>wiring diagram as well.
>Now I have a question: Has anyone ever replaced or rebuilt a 5-speed manual
>from an AWD Legacy sedan? My 261K mile vehicle has syncros that are getting
>marginal (have to double clutch and match engine rpm to avoid gear clash).
>What is involved in fixing that problem, and are there used 5-speed AWD
>transmissions out there for sale?
>Rex
>----Original Message Follows----
>From: "daniel besner" <danielbesner@hotmail.com>
>Reply-To: BC-BFLegacyWorks@yahoogroups.com
>Subject: [BC-BFLegacyWorks] a couple of questions
>Date: Sat, 28 Jul 2001 08:14:39 -0500
>MIME-Version: 1.0
>X-Originating-IP: [142.132.17.36]
>Received: from [216.115.96.57] by hotmail.com (3.2) with ESMTP id
>MHotMailBD2C0577001F40043194D8736039922F172; Sat, 28 Jul 2001 06:15:11 -0700
>Received: from [10.1.4.52] by fj.egroups.com with NNFMP; 28 Jul 2001
>13:14:53 -0000
>Received: (EGP: mail-7_2_0); 28 Jul 2001 13:14:40 -0000
>Received: (qmail 77837 invoked from network); 28 Jul 2001 13:14:39 -0000
>Received: from unknown (10.1.10.142) by m8.onelist.org with QMQP; 28 Jul
>2001 13:14:39 -0000
>Received: from unknown (HELO hotmail.com) (64.4.9.24) by mta3 with SMTP; 28
>Received: from mail pickup service by hotmail.com with Microsoft SMTPSVC;
>Sat, 28 Jul 2001 06:14:39 -0700
>Received: from 142.132.17.36 by lw9fd.law9.hotmail.msn.com with HTTP; Sat,
>28 Jul 2001 13:14:39 GMT
> From sentto-2208544-3734-996326080-rexsheldon Sat, 28 Jul 2001 06:15:31
>-0700
>X-eGroups-Return:
>sentto-2208544-3734-996326080-rexsheldon=hotmail.com@returns.onelist.com
>X-Sender: danielbesner@hotmail.com
>X-Apparently-To: BC-BFLegacyWorks@yahoogroups.com
>Message-ID: <F24NndhaqOncZfYeAqv0000a52b@hotmail.com>
>X-OriginalArrivalTime: 28 Jul 2001 13:14:39.0725 (UTC)
>FILETIME=[41DE69D01C11767]
>Mailing-List: list BC-BFLegacyWorks@yahoogroups.com; contact
>BC-BFLegacyWorks-owner@yahoogroups.com
>Delivered-To: mailing list BC-BFLegacyWorks@yahoogroups.com
>Precedence: bulk
>List-Unsubscribe: <mailto:BC-BFLegacyWorks-unsubscribe@yahoogroups.com>
>I am new to this group as I just bought my 92 Subaru Legacy AWD Turbo and I
>love it. I have been on other lists for my previous car (mazda mx-3) but
>you guys are excellent. I am having a couple of problems with the car
>though and wanted to see if anyone had any suggestions.
>1) Some power accesories work only when they want too. The sunroof and the
>power mirrors in particular. I know that someone responded on the sunroof
>and am wondering if the same is true of the mirrors.
>2) My mechanic says that the alternator is probably dying as the charging
>level is low. I don't have much experience working on cars (except stereos)
>is the labour in putting on an alternator hard at all.
>3) My air conditioning was making a noise like a lawnmower when it was on
>and then yesterday the noise stopped. To bad the air stopped with it. I am
>still getting an air flow, but it ain't conditioned. Anyone had these
>symptoms, I am guessing that my compressor bit the bucket.
>Thanks for your time,
>Dan
>92 Legacy
>Winnipeg, Manitoba, Canada
>_________________________________________________________________
>Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp
>To unsubscribe from this group, please send an email to:
>BC-BFLegacyWorks-unsubscribe@egroups.com
Small business owners...
Tell us what you think!
http://us.click.yahoo.com/vO1FAB/txzCAA ... /XoTolB/TM
a couple of questions, tranny
