Digest Number 373
Locked
subaruracer755@cs.com
Digest Number 373
Post by subaruracer755@cs.com »
i put 91 KYB AGX on my 91 sport sedan with NO headaches whatsoever... its easy, just time consuming.
1: front: unbolt top three strut tower bolts (with car in air on jackstands) remove the clip on the bracket on the strut that holds the brake line in. remove the banjo bolt that holds the brake line to the strut, fish the line through the bracket on the strut and hold it away with a ziptie or something...remove the two bolts at the bottom, of the strut, remove strut from car, swap out spring, reinstall strut oppositer of removal.
2: repeat for other front.
3: remove WHOLE rear seat assembly. your top bolts are behind the top part of the seat back. removal and installation is the same for the back, you will just nee da halper
FREE COLLEGE MONEY
CLICK HERE to search
600,000 scholarships!
http://us.click.yahoo.com/zoU8wD/4m7CAA ... /XoTolB/TM
Locked
