Hey everyone, hope your weekend is off to a good start!
On a whim today, I decided to pull a spark plug to see how it was doing. The electrode doesn't look too bad, slightly orange. The thing that got me though was what looked like oil on the threads, and around the end of the plug (engine side). I checked the oil, and it was where it had been the last time I looked, so I'm fairly sure I'm not burning oil (or at least its very little). But the threads were definitely wet, and I didn't do it!
Any ideas what this might be? I ran the car for about 10 mins prior to checking this, because I had to move it.
As always, thanks in advance!
Edit: While I've got your attention, what would cause a slightly sweet smell from the engine compartment, that I can only smell when I've got my face stuck in it? Coolant? Power steering fluid?
Oil On Spark Plug Threads?
sweet smell = coolant
if you dont have an acuall coolant leak you can still smell anti-freeze when the radiator is starting to go bad.
As far as oil on the spark plug threads . Never seen that myself.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
Great.... Not what I wanted to hear on a Saturday morning.magicmike wrote:sweet smell = coolant
if its not leaking you might still have a little time. Besides you can buy a new one for 100 bucks ish......with a lifetime warranty from like pepboys or something.
Mike
Mike
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
I don't think it's leaking. I went out and took a look at it. I'm suspecting the helpful mechanic that I had do the coolant flush - he put extra coolant in just in case there was an air pocket. I suspect its coming out the overflow and that's what I'm smelling... (Fingers crossed)
Anybody have any thoughts on the liquid on the spark plug threads?
mike-
check if your pcv valve is bad. that would cause oil on the plugs. check that before you get scared. on the coolant leak fill the sytem then pressure test it.
-Jim-
-Jim-
MY93BC Legacy Sonora Sand---> black plasti-dip?
MY93GC Impreza Amethyst--> Glacier/aspen/pd White
93BC"edm" 93GC 90BC R.I.P.
