but since i'm no electronician, i'll ask you guys what you think
Simple functionning principe (very simple)
the pressure sensor generates a voltage in relation with PSI (as we saw for building an FCD).
A certain circuit "monitor" that voltage, and once this voltage goes higher that a certain limit, it trigs a solenoid valve, wich stay opened until the voltage comes bellow the limit. (this operation would be executed several times a second, so this would produce a relatively clean boost.) . This Voltage limit should be adjustable with something like a inverted Potentionmeter.. i don't know anything in that
Is this sound stupid ? or would it become a Cheap EBC that we, poor legacy owner, could build to get a more precise _ and not variating with weather_ boost controler ?
thanx
