Can anyone recomend which of the vac pipes to take the boost gauge off
93 legacy 2.0 turbo/ there seems to be 4 vac pipes , one in the
middle near the throttle body and the outher three next to each
outher on the L/H of the inlet . ive stuck it on the middle one at
the moment , it may be me but it seems to make the car jerky when u
just come on or off the throttle and the gauge seems flick around
like mad when throttle on and off lightly or when u come off full
throttle , or is this normal
Thanx Rob
FREE COLLEGE MONEY
CLICK HERE to search
600,000 scholarships!
http://us.click.yahoo.com/47cccB/4m7CAA ... /XoTolB/TM
Boost Gauge
Boost Gauge
Cut the hose going to the boost solinoid, slip a tee in and hook up your
hose. I would cut it near the solinoid. should be reliable.
Mark
www.rrunracing.com
>Thanx Rob
Monitoring Service trial
http://us.click.yahoo.com/MDsVHB/bQ8CAA ... /XoTolB/TM
Mark
www.rrunracing.com
>Thanx Rob
Boost Gauge
Just to add to what Mark said, tap any line coming from the passenger
side tap off the intake manifold. This will get the pressure after
the turbo.
The turbo should go up and down rather quickly when on and off
throttle, this is just how the system works.
If the behaviour of the car has changed since adding the gauge, then
perhaps you've caused a leak somewhere. Remove the gauge and see if
it continues to act different.
off
> Thanx Rob
the turbo.
off
> Thanx Rob
Boost Gauge
thanx
Boost Gauge
I put a restrictor in the line for my boost guage. It seemed to cut down on
the unwanted noise alot.Boost readings didnt seem to be affected. I am using
the nipple on the intake manifold originally designated for the CBV. I am
using a different vacuum source for the CBV because it is in a different
place due to a custom intercooler being fitted. BillC
----- Original Message -----
To: <BC-BFLegacyWorks@yahoogroups.com>
Sent: Friday, September 21, 2001 51 PM
Subject: [BC-BFLegacyWorks] Boost Gauge
> Thanx Rob
> Thanx Rob
Boost Gauge
Bill,
There are 3 together, lager one and then 2 smaller ones, i use the smaller
hose on the far right. (goes to the fuel pressure regulator.)
Rod... in OZ.
Sent: Monday, September 24, 2001 10:16 AM
Subject: Re: [BC-BFLegacyWorks] Boost Gauge
on
using
> From: <rob440@hotmail.com>
> > Thanx Rob
> > Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
FREE COLLEGE MONEY
Rod... in OZ.
on
using
> > Thanx Rob
FREE COLLEGE MONEY
boost gauge
Has anyone seen those A-pillar mounted gauges? I know that Autometer
and Defi make gauge mounts for some of the other makes
(honda/mitsu/etc.) and Autometer actually has mounts for right hand
drive Subaru Legacies. Is there anything for our Legacy in left hand
drive?
Larry
Buy Stock for $4
and no minimums.
FREE Money 2002.
http://us.click.yahoo.com/k6cvND/n97DAA ... /XoTolB/TM
drive?
Larry
Buy Stock for $4
and no minimums.
FREE Money 2002.
boost gauge
It's cheaper and easier to find a universal pod mount
Sent: Monday, April 08, 2002 5:13 PM
Subject: [BC-BFLegacyWorks] boost gauge
drive?
Larry
ADVERTISEMENT
<http://rd.yahoo.com/M=213858.1981271.34 ... .tf?s=5085>
<http://us.adserver.yahoo.com/l?M=213858 ... =725134340>
drive?
Larry
ADVERTISEMENT
