5spd Swap
Locked
gtcrispy
5spd Swap
Post by gtcrispy »
Just letting you know that I've started emailing with Richard Buckner about putting a 5spd in my touring wagon. I'll keep you guys updated on whats going on with it.
Kevin
----- Original Message -----
Sent: Thursday, October 18, 2001 7:33 AM
Subject: RE: [BC-BFLegacyWorks] pcv valve
Yes Rod, I am very interested.
I want to do work to the motor on my car. Probably wouldn't be for a
bit, but I want to swap in a 5 spd and convert to AWD. I have been
toying/debating over the idea of what route to go, stick with N/A high
compression engine. Or low boost turbo setup. I've ALWAYS had a love
for turbo cars. So I would be greatly appreciate any all info you can
throw my way. Did you redo any of the engine internals. I had sorta
thought/expected to do this when I did do whatever upgrades I was goin
to do. So if I do mod engine internals, can you run more boost? or is
the N/A engine design limited?
Thanks Rod,
PS: Where in AZ are you? I got a buddy that is moving out from
Maryland area out to Tucson. He stopped by last night for dinner and
crashed at my place in memphis, and took off again this morning.
-----Original Message-----
Sent: Thu 10/18/2001 8:53 AM
Cc:
Subject: Re: [BC-BFLegacyWorks] pcv valve
I went from a NA set-up to a light pressure turbo (61/2 lbs.
boost). He put in a Garrett VB-25 dbl. roller bearing turbo (equivalent
to a T3) that spools instantly off idle. With the headers, ignition,
K&N, under drive pulley, etc. it goes like snot! If you have an NA motor
& the coin, I`d recommend this to anyone. Interested? Post me and I`ll
give you Robert`s website for more info.---ROD (AZ.)
To: 'BC-BFLegacyWorks@yahoogroups.com'
<mailto:'BC-BFLegacyWorks@yahoogroups.com'>
Sent: Wednesday, October 17, 2001 6:35 PM
so what fantastic job has been done to your car?
[mailto:roderic@cableone.net]
Sent: Thursday, October 18, 2001 2:41 PM
<mailto:BC-BFLegacyWorks@yahoogroups.com>
Just a note on the PCV valve: if it ain`t broke,
don`t fix it! This comes from someone with extended Subie knowledge as a
tech & is the guy who did the fantastic job on my turbo set-up. The PCV
Subaru uses is`nt like the old ones you`d find in a rubber grommet
stuck in the valve cover. This one is in the pass. side of the throttle
body just above the IAC valve. When i asked if it should be changed, he
indicated they don`t get all oiled up like the old ones did & it was OK.
Do what you`re comfortable with, but it`s probably OK. My 2 cents
worth---ROD (AZ.)
<mailto:nissans14@yahoo.com>
Sent: Wednesday, October 17, 2001 5:45
PM
Subject: [BC-BFLegacyWorks] pcv valve
also can somene tell me where PCV valve
is located...
do you just replace this or clean it
out? Is it a good
idea to do so if i have 129k miles and
don't know if
its ever been replaced? (im having rough
idle and bad
gas milage)
--- jason grahn < jgrahn555@hotmail.com
<mailto:jgrahn555@hotmail.com> > wrote:
> located in the engine bay, on the
battery side near
> the strut tower. get an
> OEM filter.. If you get the filter
1st, you'll see
> where yours is no prob..
> -Jason
> >where is the fuel filter located on a
1991 sport
> >sedan? I'm going to replace it
tomorrow morning...
> any
> >brands that any one recommends? part
numbers? any
> tips
> >on replacing it? i would imagine its
pretty simple
> >just have to watch out for gas going
> everywhere...can
> >someoen tell me where its
located...what it looks
> like?
> Get your FREE download of MSN Explorer
at
> http://explorer.msn.com/intl.asp
Do You Yahoo!?
Make a great connection at Yahoo!
Personals.
http://personals.yahoo.com
To unsubscribe from this group, please
send an email to:
Your use of Yahoo! Groups is subject to
the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
To unsubscribe from this group, please send an
email to:
Your use of Yahoo! Groups is subject to the
Your use of Yahoo! Groups is subject to the Yahoo! Terms
Your use of Yahoo! Groups is subject to the Yahoo! Terms of
ADVERTISEMENT
<http://rd.yahoo.com/M=194081.1637497.31 ... ?code=3257> Click Here!
<http://us.adserver.yahoo.com/l?M=194081 ... =572556127>
Locked
