I got a price quote from Richard Buckner on how much it would cost to convert my 93' Legacy Touring Wagon to a 5spd manual.. Here is what he sent me. Maybe it will help some of you, who might be interested. I'm still not quite sure what I'm going to do..All i know is I better start saving
5 speed out of a Legacy or Impreza with 4.11 final drive
matching rear final drive
pedal assembly
shifter equipment/assembly
This trans will will not be an actual Turbo "pull type", it will be a push type. These are less expensive and readily available. The guts are basically identical. The lower final drive, ( you have 3.90's now), will give you better acceleration and it will relieve stress on the gears. The ECU will need to be wired to M/T and a starter relay will need to be installed. The used trans should be rebuilt, new bearings and synchros.
Cost?
trans. $850.00
rebuild $875.84 parts
diff., shifter, & misc. $450.00
clutch, P/P, Disk, T/O bearing $275.00
labor, R&R trans, rebuild, rewire, swap diffs. $750.00
total $3200.54
ADVERTISEMENT
<http://rd.yahoo.com/M=194081.1637497.31 ... ?code=3274>
<http://us.adserver.yahoo.com/l?M=194081 ... =977735546>
