anybody using anAPEXi EBC?
I've been thinking about a boost controller and was wondering if anyone has as electronic boost controller installed. I've heard about the APEXi and others but what has been a sucessful device to use?
1993 Turbo Wagon Stock w/turbo back 3"exh, KYB's
I've used an AVC-R for over two years, though i still don't know very much about its specifics and all of the stuff it can do. It's been a worthwhile investment though.
Legacy Central
I've got a ton of questions: like installation; did you install it yourself? is it a plug and play device? How about programming? is it straightforward enough to be done by yourself? Other mods to help? ie. fuel management, IC, exhaust, ... Ever had reliability issues?
thanks, Larry
thanks, Larry
I have the AVC-R for about 2 year also and I installed all by myself.
You have to make sure all the wire from your ecu pin out and you have to do some hose re-route for the installation!
The unit only control the boost, I also runs with the 93 WRX intercooler and I am now with BC5 engine so the boost is set around 16psi.
The unit is well design but you have to put lots of time to do the setting since it really hard to give it a good setting. You could do your setting while you are driving or ask someone to drive your car and you could do the setting!
Ben
Ben
92 Legacy turbo with EJ20G engine swap \(^0^)/
I had it professionally installed and setup.
It's rather complicated, honestly, so if you're interested in it, i'd download the manuals from Apexi and look over them.
DAve
DAve
Legacy Central
I'm not sure what you're looking for. Mine's probably out of tune since it was installed in an automatic and is now a 5MT.
Legacy Central
