dog-box???
Locked
Nissan-Subaru
dog-box???
Post by Nissan-Subaru »
whats a dogbox? I'm guessing its some kind of transmission. Who makes it? how much? where do you get it?
_____
Do You Yahoo!?
Find the one for you at Yahoo! Personals <http://rd.yahoo.com/mktg/mail/txt/tagli ... .yahoo.com> .
ADVERTISEMENT
<http://rd.yahoo.com/M=213858.1737107.32 ... .tf?s=5085>
<http://us.adserver.yahoo.com/l?M=213858 ... =469974328>
Josh Colombo
dog-box???
Post by Josh Colombo »
Dogbox is referring to the Gear type. You will hear the term dogboxed gearset thrown around by people with High HP engines. Most transmissions have helical gears, they are slanted or turned sideways, the reason is that they mesh easier and are alot quieter, do to the fact you have gradual surface area of the gears mating, rather then with straight cut gears the mating surface mates all at one time, and is noisier. Like I said with the straight cut, ie dog boxed gears, the mating surface mates all at once, so the teeth can take more force on them. Downside, they are noisey, and usually require double clutching when shifting.....or so I've been told. A usual thing is to go with straight cut gears for 1st and 2nd and helical gears for the rest, cause torque wouldn't be as much.
-----Original Message-----
Sent: Fri 11/16/2001 7:40 AM
Cc:
Subject: [BC-BFLegacyWorks] dog-box???
_____
Do You Yahoo!?
Find the one for you at Yahoo! <http://rd.yahoo.com/mktg/mail/txt/tagli ... .yahoo.com> Personals.
ADVERTISEMENT
Mark Ward
dog-box???
Post by Mark Ward »
Check our www.mrtrally.com and look up their "unbreakable gear set". I
dont believe you need to clutch at all except when starting.
Mark
>Josh
> From: Nissan-Subaru
> Cc:
> _____
> Do You Yahoo!?
>ADVERTISEMENT
><http://rd.yahoo.com/M=213858.1737107.32 ... web/S=1705
>064983:HM/A=763352/R=0/*http://www.classmates.com/index.tf?s=5085>
><http://us.adserver.yahoo.com/l?M=213858 ... 74/D=egrou
>pmail/S=1705064983:HM/A=763352/rand=469974328>
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>Service <http://docs.yahoo.com/info/terms/> .
Universal Inkjet Refill Kit $29.95
Refill any ink cartridge for less!
Includes black and color ink.
http://us.click.yahoo.com/XwUZwC/MkNDAA ... /XoTolB/TM
Daniel Wilson
dog-box???
Post by Daniel Wilson »
Depends on how you change gears if you match engine revs then you
don't even need to use the clutch.
StartMeUp jump starts your car's battery
using only the cigarette lighter.
$24.95 at Youcansave.com
http://us.click.yahoo.com/20gskB/LTTDAA ... /XoTolB/TM
Josh Colombo
dog-box???
When you say match engine revs, you mean match speed and revs, or just
get it so there is no pressure on the gears?
Josh Colombo
Josh@surrealmirage.com <mailto:Josh@surrealmirage.com> **NEW**
of beats and rhythm" - ME
From: Daniel Wilson [mailto:daniel.wilson@db.co.nz]
Sent: Sunday, November 18, 2001 18 PM
Subject: [BC-BFLegacyWorks] Re: dog-box???
Daniel Wilson
dog-box???
So the engine speed is the same as the gearbox speed during the
change.
just
http://us.click.yahoo.com/qbucSA/LTTDAA ... /XoTolB/TM
Brett Middleton
dog-box???
Post by Brett Middleton »
we do recommend you use ity as the gear set dogs will last longer, BUT no
you dont HAVE to!
Brett Middleton
MRT Performance
We Rally, You Win (STi Version 5)
http://www.MRTrally.com.au <http://www.mrtrally.com.au/> main pages
http://www.MRTrally.com.au/shop <http://www.mrtrally.com.au/shop> buy on
line
> From: Mark Ward [mailto:mark@rrunracing.com]
> Sent: Saturday, 17 November 2001 02:50
> Subject: RE: [BC-BFLegacyWorks] dog-box???
> gear set". I
> Mark
> term dogboxed
> sideways,
> to the fact
> clutching
> rest, cause
> >Josh
> > From: Nissan-Subaru
> > Cc:
> transmission. Who
> > _____
> > Do You Yahoo!?
> ><http://rd.yahoo.com/mktg/mail/txt/tagli ... /personals.
yahoo.com>
>ADVERTISEMENT
http://us.click.yahoo.com/k4tJlC/LTTDAA ... /XoTolB/TM
Locked
