Ok with all this sunroof talk its got me thinking about mine.
OK...here goes... I bought it..sunroof worked. Few days later...it
didnt. Then it did...then it would work one minute and not the
next. Now it just doesnt. I dont really try because it cold out
now...and if it got stuck open i'd be up sh!t creek. Anyway....has
anyone else had this prob? I dont think its the motor if it goes
intermittently like that. What could it be? Thanks for any help!
Break free. Great
American Smokeout
http://us.click.yahoo.com/3vN8tD/.pSDAA ... /XoTolB/TM
Sunroof BS.
Sunroof BS.
sounds like a lose conection...
if it gets stuck open i thnk you can close it manually... should be a tool in the arm rest.
_____
Do You Yahoo!?
Check out Yahoo! Shopping <http://rd.yahoo.com/O=1/I=mail/footer/* ... .yahoo.com> and Yahoo! Auctions <http://rd.yahoo.com/O=1/I=mail/footer/* ... .yahoo.com> for all of your holiday gifts!
ADVERTISEMENT
<http://rd.yahoo.com/M=178320.1681224.32 ... /yahoo-57f>
<http://us.adserver.yahoo.com/l?M=178320 ... =650628600>
_____
Do You Yahoo!?
ADVERTISEMENT
Sunroof BS.
I had this problem in my old 91 Legacy Turbo. Sometimes it wouldnt open. Sometimes it would. I figured out my reason was that the rubber seal of the glass would get hung up on the roof when coming down. If you lightly hit the glass on the back part of the glass, it will pop loose and continue to open. BTW, I never had a problem with it not closing.
Ian D.
93 Legacy Turbo
Promise to Quit
Nicotrol will help
http://us.click.yahoo.com/5vN8tD/AqSDAA ... /XoTolB/TM
Ian D.
93 Legacy Turbo
Promise to Quit
Nicotrol will help
Sunroof BS.
Yup, I have the same exact problem with my '92 Legacy Turbo. It works one
second and doesn't work the next. Sometimes I just wait a few seconds or
minutes and try it again and she will open/close no problem. I don't think
it's the motor either. It seems like there is some kinda loose connection or
something around the switch area. But it affects all of the buttons (the
open,close and tilt). I've tried on some occasions to use my hand to bang
around the switch area while holding down the button which proved to be
successful most of the time! But towards the end of the summer (the last time
I used it) it didn't seem to work that much and I had to just wait it out.
I'd like to know how to get this fixed also if anyone else can shed some
light on this.
FREDDEX
------------------( Forwarded letter 1 follows )--------------------
Date: Fri, 14 Dec 2001 06:311 -0000
Sender: sentto-2208544-5860-@gcs.alias
Reply-To: BC-BFLegacyWorks@yahoogroups.com
Subject: [BC-BFLegacyWorks] Sunroof BS.
light on this.
FREDDEX
Sunroof BS.
I had this problem a couple years ago, I pulled the cover off of the
controls (going on memory here may not be totally accurate) I think there
are one or two grounding points under those screws, simply clean and
reinstall. BUT, my sunroof leaked so bad I finally just sealed it off and
don't use it - my car was rolled up onto it's side by the P.O. and a new
sunroof was installed and has leaked ever since I bought it
PeteH
> Message: 1
> Date: Fri, 14 Dec 2001 10:417 EST
> From: TurboSubie91@aol.com
> Subject: Re: Sunroof BS.
> Ian D.
> 93 Legacy Turbo
> Message: 2
> Date: Fri, 14 Dec 2001 11:540 -0500
> From: FREDERICK.WHITMORE@CN.CA
> Subject: Sunroof BS.
think
or
time
> light on this.
> FREDDEX
Tiny Wireless Camera under $80!
Order Now! FREE VCR Commander!
Click Here - Only 1 Day Left!
http://us.click.yahoo.com/75YKVC/7.PDAA ... /XoTolB/TM
PeteH
> Message: 1
> Ian D.
> 93 Legacy Turbo
> Message: 2
think
or
time
> light on this.
> FREDDEX
