5MT Swap
Austin
5MT Swap
Post by Austin »
I'm changing out the 5MT in my 91 Legacy turbo.
Is it necessary to remove the 10mm allen head plug on the driver's side of the tranny and pull the clutch release fork shaft (the one you screw a 6mm bolt into to remove) out of the tranny *before* removing from the car?
91 Turbo Legacy Sedan 5MT
02 Impreza WRX Sedan 5MT
02 Legacy Sedan 5MT
