I want to tell my ECU that i'm running an MT. You said to cut B48
#20.
How do i find out which wire this is?
Buy Stock for $4.
No Minimums.
FREE Money 2002.
http://us.click.yahoo.com/BgmYkB/VovDAA ... /XoTolB/TM
Al: How do i find B48 #20 on the ECU?
Plug B48 is the next to the largest plug on the ECU and has 22pins.
Pins 2 and 13 are the main power to the ECU and are the larger
yellow/red wires. So I would just count over from the power wire on
the bottom row of pins to pin number 20 I think it is a black/white
wire. I would check my diagrams but they are all at work where I am
trying to rewire a Impreza with a European EJ20 in it. I never did see
much change that I can remember but then again I don't know if I ran
one of the conversions without cutting the wire either.I guess what I
need is a better memory.
--- In BC-BFLegacyWorks@y..., "legacycentral" <legacycentral@y...>
> #20.
> Dave
Buy Stock for $4.
No Minimums.
FREE Money 2002.
> #20.
> Dave
Buy Stock for $4.
No Minimums.
FREE Money 2002.
Did you get a chance to make sure this is the correct wire?
I really don't want to snip the wrong one!
--- In BC-BFLegacyWorks@y..., "milehial2000" <acroxford@h...>
22pins.
larger
wire on
white
I am
did see
if I ran
what I
Buy Stock for $4.
No Minimums.
FREE Money 2002.
22pins.
larger
wire on
white
I am
did see
if I ran
what I
Buy Stock for $4.
No Minimums.
FREE Money 2002.
That should be the right wire.
AL(CO)
> Dave
> 22pins.
> larger
> wire on
> white
> I am
> did see
> if I ran
> what I
Access Your PC from Anywhere
Check Email & Transfer files - Free Download
http://us.click.yahoo.com/omECdA/3XkDAA ... /XoTolB/TM
AL(CO)
> Dave
> 22pins.
> larger
> wire on
> white
> I am
> did see
> if I ran
> what I
