Question about the MAF
I was reading about an auction on ebay and it kinda
said this can anyone tell me if this is right?
If you have a manual sport sedan then the part your
MAF is connected to is metal
If you have an auto sport sedan then the part your MAF
connects to is plastic.
Is this right?
__________________________________________________
Do You Yahoo!?
Try FREE Yahoo! Mail - the world's greatest free email!
http://mail.yahoo.com/
Access Your PC from Anywhere
Check Email & Transfer files - Free Download
http://us.click.yahoo.com/omECdA/3XkDAA ... /XoTolB/TM
MAFs
MAFs
The n/a engines use a plastic MAF I have one here with the part#
22680AA160F the metal MAF is used on the turbo models with the
exception of a few early n/a cars that we think were actually '89
production as they use a different IAC and other parts also. The
metal
unit has the number 170 in the part# (my metal MAF is over at the
shop
with my EJ20 project) as far as I know the metal MAF will sub for the
plastic one but is quite a bit more expensive( at one time they were
$400+) but the plastic MAF will not sub for the metal unit YET. If I
find that the injectors for the EJ20 are different I will be working
on a mod for the plastic unit to run it on the EJ20 turbo engine.
> said this… can anyone tell me if this is right?
> Is this right?
> Do You Yahoo!?
Full setup in 2 minutes! - Free Download
http://us.click.yahoo.com/pmECdA/2XkDAA ... /XoTolB/TM
metal
shop
> Is this right?
> Do You Yahoo!?
MAFs
This may be a duplicate I think my previous message went to data
heaven. The plastic MAF units were used on all n/a engines except some
early producton n/a cars that we think were '89 production. I have a
plastic unit here with the part #22680 AA160F. The metal MAF was used
on all turbo engine that I know of and has a part# with 170 in it (
mine is at the shop with my EJ20 project) and is expensive last I
heard they were $400+. I believe that the metal MAF will sub for the
plastic one and know the plastic MAF will not sub for the metal unit
YET. If I find that the injectors are larger than the EJ22t I will be
working on a mod to the plastic MAF to use it on the turbo motors.
> Is this right?
> Do You Yahoo!?
It's Easy. It's Fast. - Free Download
http://us.click.yahoo.com/lmECdA/6XkDAA ... /XoTolB/TM
> Is this right?
> Do You Yahoo!?
MAFs
To confirm what Al said.
I believe in June or July of 89 they switched stuff on the 90 MY legacies. I believe mine was the first month it got switched....I had to get the more expensive O2 sensor.....and I do have a plastic MAF sensor.
I wonder if the metal sensors are tougher....or do send different signals?
josh
-----Original Message-----
From: milehial2000 [mailto:acroxford@hypermall.net]
Sent: Mon 3/11/2002 7:50 AM
Cc:
Subject: [BC-BFLegacyWorks] Re: MAFs
metal
shop
> Is this right?
> Do You Yahoo!?
josh
Cc:
metal
shop
> Is this right?
> Do You Yahoo!?
MAFs
I don't think that they are any tougher and unless the ECU's are
different internally the signals are very close to being the same. The
EJ20 is running good now with 15lbs of boost and doesn't appear to
have any mixture problems other than running a bit lean on the top end
and this is because of the factoy fuel pump that will be replaced so I
think the injectors are close also.
AL(CO)
sensor.
signals?
> josh
> From: milehial2000 [mailto:acroxford@h...]
> To: BC-BFLegacyWorks@y...
> Cc:
part#
'89
The
> metal
the
> shop
for the
they were
YET. If I
working
engine.
> > Is this right?
> > Do You Yahoo!?
> BC-BFLegacyWorks-unsubscribe@e...
> Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
AL(CO)
sensor.
signals?
> josh
> Cc:
part#
'89
The
> metal
the
> shop
for the
they were
YET. If I
working
engine.
> > Is this right?
> > Do You Yahoo!?
MAFs
You guys runnin high boost.....have you ever considered, or looked into changing the fuel delivery setup from series to parallel. I have heard of some issues with some of the folks turboing the imprezas, with the #3 cylinder leaning out. I haven't heard anything about it with the turbo legacies....either they're not puttin out as much power...which I sorta don't think so.....or the stuff on the newer cars are cheaper....and not as good flowing.
Here's a link to a write-up and pics. http://www.scoobymods.com/forums/showth ... readid=175
Josh Colombo
Josh@surrealmirage.com <mailto:Josh@surrealmirage.com> **NEW**
of beats and rhythm" - ME
Sent: Monday, March 11, 2002 81 PM
AL(CO)
sensor.
signals?
> josh
> Cc:
part#
'89
The
> metal
the
> shop
for the
they were
YET. If I
working
engine.
> > said thisâEUR¦ can anyone tell me if this is right?
> > Is this right?
> > Do You Yahoo!?
Josh Colombo
AL(CO)
sensor.
signals?
> josh
> Cc:
part#
'89
The
> metal
the
> shop
for the
they were
YET. If I
working
engine.
> > Is this right?
> > Do You Yahoo!?
MAFs
We looked at it and were a little perplexed as it seems that #4 is the
only place that we could find any evidence of a lean condition at
very high RPM and 26lbs boost before we discovered the fuel
delivery problem and seeing that the factory chose this location for
the knock sensor our thoughts were that possibly the manifold is
causing this.
AL(CO)
http://www.scoobymods.com/forums/showth ... 2107431e4e
0b1c2fe75e7c&threadid=175
> Josh Colombo
> Josh@s... <mailto:Josh@s...> **NEW**
The
end
I
> AL(CO)
had
> sensor.
> signals?
> > josh
> > Cc:
> part#
> '89
> The
> > metal
> the
> > shop
> for the
> they were
> YET. If I
> working
> engine.
> > > Is this right?
> > > Do You Yahoo!?
causing this.
AL(CO)
> Josh Colombo
The
end
I
> AL(CO)
had
> sensor.
> signals?
> > josh
> > Cc:
> part#
> '89
> The
> > metal
> the
> > shop
> for the
> they were
> YET. If I
> working
> engine.
> > > Is this right?
> > > Do You Yahoo!?
MAFs
hmmm....that's interesting. I wonder if it is more a problem with the newer subaru's or even just imprezas.
Is there a way to hook up a pressure sendor or something like that to each line going to each injector to measure individual pressures and see if there is a big variance?
When you did some testing......was this on a stock engine, parts, fuel, etc? Or was it modified.
I would assume that the imprezas have a less flow fuel pump compared to the turbo legacy.....know if this is true or not?
Just tryin to see if this would be a worthwhile mod for an engine that was originally N/A and converted to a turbo.
josh
Sent: Tue 3/12/2002 11:30 AM
Cc:
causing this.
AL(CO)
> Josh Colombo
The
end
I
> AL(CO)
had
> sensor.
> signals?
> > josh
> > Cc:
> part#
> '89
> The
> > metal
> the
> > shop
> for the
> they were
> YET. If I
> working
> engine.
> > > Is this right?
> > > Do You Yahoo!?
josh
Cc:
causing this.
AL(CO)
> Josh Colombo
The
end
I
> AL(CO)
had
> sensor.
> signals?
> > josh
> > Cc:
> part#
> '89
> The
> > metal
> the
> > shop
> for the
> they were
> YET. If I
> working
> engine.
> > > Is this right?
> > > Do You Yahoo!?
MAFs
The car was modified when we were running it at Bandimere raceway in
Denver it was turning 13.5 1/4 mile times and would have done about
12.5 at sea level. The fuel pump would certainly be a good mod for any
car that has been taken out of it's original configuration or has had
the engine modified. I don't think that a accurate gauge could be
mounted at the injectors because of the pulses but if you place a
pressure gauge in the fuel line it will drop at high rpm at least that
is how we found it. It seems that Subaru gives a pump that is just
enough for the engine and after installing the EJ22t in my '95 Impreza
I installed a 255 lph pump and it showed quite an improvement. And I
am pretty sure that the Legacy Turbo has a different pump than the n/a
version.
AL(CO)
> josh
> Cc:
#4 is the
at
location for
is
> causing this.
> AL(CO)
looked
I have
imprezas,
about it
much
newer
> > Josh Colombo
are
same.
> The
appear to
the top
> end
replaced so
> I
> > AL(CO)
90 MY
switched....I
> had
plastic MAF
> > sensor.
different
> > signals?
> > > josh
> > > Cc:
the
> > part#
with the
actually
> > '89
also.
> > The
> > > metal
over at
> > the
> > > shop
will sub
> > for the
time
> > they were
unit
> > YET. If I
will be
> > working
turbo
> > engine.
<nissans14@y...>
right?
MAF
> > > > Is this right?
> > > > Do You Yahoo!?
email!
to:
version.
AL(CO)
> josh
> Cc:
#4 is the
at
location for
is
> causing this.
> AL(CO)
looked
I have
imprezas,
about it
much
newer
> > Josh Colombo
are
same.
> The
appear to
the top
> end
replaced so
> I
> > AL(CO)
90 MY
switched....I
> had
plastic MAF
> > sensor.
different
> > signals?
> > > josh
> > > Cc:
the
> > part#
with the
actually
> > '89
also.
> > The
> > > metal
over at
> > the
> > > shop
will sub
> > for the
time
> > they were
unit
> > YET. If I
will be
> > working
turbo
> > engine.
<nissans14@y...>
right?
MAF
> > > > Is this right?
> > > > Do You Yahoo!?
email!
to:
