I found a leak today. On the driver side of the engine
is this black box thing that’s leaking radiator fluid.
What’s this thing called? I think JC sports used to
make a metal one. Do I have any other choice besides
the OE one? Anyone have a part # can anyone give me an
idea on price? Also Is there anyway I can stop the
leak for a little longer?
__________________________________________________
Do You Yahoo!?
Yahoo! Tax Center - online filing with TurboTax
http://taxes.yahoo.com/
Buy Stock for $4.
No Minimums.
FREE Money 2002.
http://us.click.yahoo.com/k6cvND/n97DAA ... /XoTolB/TM
Leaking coolant
Leaking coolant
Yeah, I believe this is your oil reservoir. One of the nipples on my
broke on a cold day under the hood so I had to repair it with a new
nipple(fossat nossle) and tacked it with some JB Weld. Locate the leak
and putty it up with some JB Weld or like RV/Marine Silicone. It will
hold for a little bit. You may need to drain and remove the oil
reservoir, also a good time to really flush it out with a good flow of
water(maybe some soap???), as I did.
see ya,
ryan-
>is this black box thing that's leaking radiator fluid.
>What's this thing called? I think JC sports used to
>Do You Yahoo!?
Buy Stock for $4.
No Minimums.
FREE Money 2002.
see ya,
ryan-
>Do You Yahoo!?
Buy Stock for $4.
No Minimums.
FREE Money 2002.
Leaking coolant
No, that's a coolant resevoir. Ryan, i may have to revoke your legacy if you
keep piping up with wrong answers before checking your service manuals. ;-P
-Jason
Chat with friends online, try MSN Messenger: http://messenger.msn.com
Buy Stock for $4.
No Minimums.
FREE Money 2002.
-Jason
Buy Stock for $4.
No Minimums.
FREE Money 2002.
Leaking coolant
John Nissan-Subaru <nissans14@yahoo.com> has broken his coolant expansion tank
John you should have known better than to get too close to that tank. Body heat causes it to come apart usually where the fittings for the coolant lines enter the tank. JB weld held mine together for a couple of years. I built up the epoxy around the fittings just hoping for a workable seal, but it eventually started leaking again. I scored an Aluminum one from the last batch made by JC Sports. I would send off to MRT in Australia for their Aluminum version before I would fork out a couple of hundred for another stock one.
Larry Witherspoon
Torrance (Los Angeles)
ssspoon@aol.com
ADVERTISEMENT
<http://rd.yahoo.com/M=215002.1954253.34 ... 000239/R=1>
<http://us.adserver.yahoo.com/l?M=215002 ... =680861774>
Larry Witherspoon
ssspoon@aol.com
ADVERTISEMENT
Leaking coolant
In another email someone said its called the coolant
reservoir. I called the dealer yesterday and they said
it would be $80…. Did I ask for the wrong part?
> > tank
> Australia for their
> hundred for another
> stock one.
> Larry Witherspoon
> ssspoon@aol.com
Do You Yahoo!?
Buy Stock for $4.
No Minimums.
FREE Money 2002.
> > tank
> Australia for their
> hundred for another
> stock one.
> Larry Witherspoon
> ssspoon@aol.com
Do You Yahoo!?
Buy Stock for $4.
No Minimums.
FREE Money 2002.
