I tested it on the dyno located at Matrix Integrated in Portland Oregon. It is a Mustang Dynometer.
I first ran a baseline run without the supercharger. Max power was 75.7 hp at 5250 rpm. Max torque was 92.5 at 2750 rpm. Power and torque were most likely much lower than they should have been because airflow is constricted due to having to flow through the supercharger and intercooler, plus I was retarding timing 4% between 4000 rpm and 6500 with my DIS-4.
Then came the supercharger pulls. I did two pulls and they were identical. 152.3 hp at 5500 rpm and 159.1 torque at 4250 rpm. I will post the dyno sheet in a few hours and possibly the video if I get it converted.
