Center Diff Question
morgie
Post by morgie »
I'm planning on changing the center diff (visco) cuz mine jam / locks after 5-10min of highway.
My question is simple : Can you check into the Manual to see if i need to put oil in there, and if so, what kind ! :)
thanx !
morgie
'98 4Runner V6 Manual 4x4.
the center diff is a sealed unit, you can't service it.
morgie
Post by morgie »
i'm talking about the complete "center diff" unit. not just the viscous-coupling part
i'll upload a pic in a sec
morgie
morgie
Post by morgie »
that's the thing i'm talking about... apparently, this is in a case bolted to the back of the tranny (that's where it comes from)
HiRes : http://images3.fotki.com/v29/free/b857d ... img-or.jpg
morgie
FSM doesn't say anything about oil or anything. There's some needle bearings in there. I'd probably add some grease in there, since you're disassembling. You'll probably want to change the trans oil after 100 some miles of putting a new unit in.
morgie
Post by morgie »
I'm still in the process of changing it , it's a quite simple process, but there is a lot of "You must know that little detail or you'll be fu****" ...
will post a little "howto" with pics soon :)
morgie
eastbaysubaru
Post by eastbaysubaru »
A How To would be awesome. It's great to be involved in a community where everyone is down to help out. Can ya feel the love :D
-Brian
'04 PSM FXT
Mark Ward
Post by Mark Ward »
The center diff shares oil with the tranny and front diff..
Its pretty easy to replace.
Mark
ciper
Post by ciper »
Mark Ward: It shares the lubricating oil with the transmission, however the LSD fluid is completly sealed and non servicable.
morgie
Post by morgie »
"Another job well done" !
With the right tools, it's a pretty easy job... i had to use a Zip-Gun to remove the "T" from the shifter shaft ... a tool that i didn't have... but a pretty kind friend lended to me.
morgie
morgie
Post by morgie »
The parts in place, just removed the rear-cover (usefull pic for re-assembly)
The Center-Diff / Viscous Coupling Casing, and the output shaft
Their emplacement.
morgie
cool.....good work!
