Moderators: Helpinators , Moderators
morgie
Posts: 743 Joined: Wed Oct 30, 2002 12:55 am
Post
by morgie » Sat Jun 21, 2003 12:59 pm
I'm planning on changing the center diff (visco) cuz mine jam / locks after 5-10min of highway.
My question is simple : Can you check into the Manual to see if i need to put oil in there, and if so, what kind !
thanx !
morgie
'98 4Runner V6 Manual 4x4.
Posts: 27928 Joined: Tue Oct 15, 2002 11:37 am
Post
by Legacy777 » Sat Jun 21, 2003 10:17 pm
the center diff is a sealed unit, you can't service it.
morgie
Post
by morgie » Sun Jun 22, 2003 12:23 am
i'm talking about the complete "center diff" unit. not just the viscous-coupling part
i'll upload a pic in a sec
morgie
morgie
Post
by morgie » Sun Jun 22, 2003 12:39 am
that's the thing i'm talking about... apparently, this is in a case bolted to the back of the tranny (that's where it comes from)
HiRes :
http://images3.fotki.com/v29/free/b857d ... img-or.jpg
morgie
Post
by Legacy777 » Sun Jun 22, 2003 2:13 am
FSM doesn't say anything about oil or anything. There's some needle bearings in there. I'd probably add some grease in there, since you're disassembling. You'll probably want to change the trans oil after 100 some miles of putting a new unit in.
morgie
Post
by morgie » Wed Jun 25, 2003 1:13 am
I'm still in the process of changing it , it's a quite simple process, but there is a lot of "You must know that little detail or you'll be fu****" ...
will post a little "howto" with pics soon
morgie
eastbaysubaru
Posts: 1312 Joined: Wed Oct 16, 2002 10:44 pm
Post
by eastbaysubaru » Wed Jun 25, 2003 1:36 am
A How To would be awesome. It's great to be involved in a community where everyone is down to help out. Can ya feel the love
-Brian
'04 PSM FXT
Mark Ward
Posts: 82 Joined: Fri Oct 18, 2002 2:41 am
Post
by Mark Ward » Thu Jun 26, 2003 2:47 am
The center diff shares oil with the tranny and front diff..
Its pretty easy to replace.
Mark
ciper
Posts: 4388 Joined: Tue Oct 15, 2002 8:16 pm
Post
by ciper » Thu Jun 26, 2003 5:31 am
Mark Ward: It shares the lubricating oil with the transmission, however the LSD fluid is completly sealed and non servicable.
morgie
Post
by morgie » Fri Jun 27, 2003 4:58 pm
"Another job well done" !
With the right tools, it's a pretty easy job... i had to use a Zip-Gun to remove the "T" from the shifter shaft ... a tool that i didn't have... but a pretty kind friend lended to me.
morgie
morgie
Post
by morgie » Fri Jun 27, 2003 9:28 pm
The parts in place, just removed the rear-cover (usefull pic for re-assembly)
The Center-Diff / Viscous Coupling Casing, and the output shaft
Their emplacement.
morgie
Post
by Legacy777 » Sat Jun 28, 2003 1:23 am
cool.....good work!
