Transmission on legacy 1990
Alpocalypse
Post by Alpocalypse »
Hi,
I purchased a used legacy 1990 that had a swap for a 2.2 turbo and I am wondering how I can tell if the transmission in is the one from the original atmospheric setup or the one that goes with the EJ22 turbo.
How can I find out ?
I brought the car with the motor blew up and I am about to put a WRX block in it. I need to know if I have a transmission that can handle it or should I replace it for another one. If it can help here are the numbers I see on the transmission after removal of the block.
241206
IT-TY752VA1AA
In snow we ride !
THAWA
Post by THAWA »
Hmm, sounds like a manual. Is the clutch a cable setup or hydraulic? Better yet, did you have to do anythign with the clutch fork to get the engine out of the car?
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
Alpocalypse
Hi the clutch gas a cable and does not seem to have anything hydrolic.
For the motor removal, I don't know since I purchased the car with the motor removed.
In snow we ride !
THAWA
Post by THAWA »
Oh, well it's the original trans.
Alpocalypse
You think it could handle 250hp ?
And do you know if the ratio is 4:11 ?
In snow we ride !
THAWA
Post by THAWA »
Not as easily as a different transmission could.
Assuming it's stock, Yes.
