Hi,
I purchased a used legacy 1990 that had a swap for a 2.2 turbo and I am wondering how I can tell if the transmission in is the one from the original atmospheric setup or the one that goes with the EJ22 turbo.
How can I find out ?
I brought the car with the motor blew up and I am about to put a WRX block in it. I need to know if I have a transmission that can handle it or should I replace it for another one. If it can help here are the numbers I see on the transmission after removal of the block.
241206
IT-TY752VA1AA
Transmission on legacy 1990
In snow we ride !
Hmm, sounds like a manual. Is the clutch a cable setup or hydraulic? Better yet, did you have to do anythign with the clutch fork to get the engine out of the car?
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
Not as easily as a different transmission could.
Assuming it's stock, Yes.
