How to get the damn seatbelt light from blinking?
douglas vincent
Post by douglas vincent »
It never goes off. No matter what.
Is there an easy fix?
IronMonkeyL255
Post by IronMonkeyL255 »
Did you swap seatbelts, or do you still have your automatic ones.
I ended up removing the seatbelt control unit after my swap to get it to turn off.
Rio Red '91 Legacy SS
gt2.5turbo
Post by gt2.5turbo »
i have the same issue... it happened right after i did my tranny swap thought and i still have the autos.
93 White Legacy Turbo Wagon: For Sale-ish
93 White Turbo Sedan: soon with a little more umf
91, funky brown purple gray color, legacy L Wagon: the "its so cheap i cant not pass it up" purchase to get me around when the others are down
douglas vincent
I have the automatic ones.
Brat4by4
Stratified
Post by Brat4by4 »
Is taking the bulb out of the dash an option?
DLC
Post by DLC »
Probably need to jump something so that it thinks your belt is constantly latched.
Legacy Central
schspeedster
Post by schspeedster »
Brat4by4 wrote:Is taking the bulb out of the dash an option?
Have cluster out, just took the bulb and moved it to the empty AT OIL TEMP socket. Also going to disconnect the wires to the annoying beeper, in the cluster right over the speedo.
