Random CE Light
Manarius
Random CE Light
I pulled out of my driveway yesterday and was 2 minutes down the road and the CE light came on...then about 10 seconds later it went off. Sign of a larger problem or something I should ignore?
Manarius
No, not really. I would be more inclined to pull the code if it stayed. I thought that maybe you or someone else would know or had ever seen something like it before. But, if you're going to treat it like that..fine be that way.vrg3 wrote:Yeah, what is this, a joke?
Manarius
I pulled the codes. If they are in chronological order; they came like this:
22 - Knock Sensor
24 - Air Control Valve
32 - O2 sensor (I guess this would be the one that caught me last night)
Now, suggestions? The light doesn't stay on all the time, these are just the stored codes.
22 - Knock Sensor
Manarius
91 Non-Turbo AT.
Which one of those is the sensor that gets affected when it gets wet?
