Moderators: Helpinators , Moderators
Splinter
Posts: 3058 Joined: Tue Aug 02, 2005 11:12 pm
Post
by Splinter » Fri May 26, 2006 7:10 am
I dont know how obvious this is, but Id thought Id throw it out there.
For those of you who have removed your AC, but left the evaporator in because you didnt have anything to plug the firewall with:
Tada!
Just pull the rubber boot off the evaporator assembly and use some silicon sealer to fill the holes. Works like a charm.
Posts: 27936 Joined: Tue Oct 15, 2002 11:37 am
Post
by Legacy777 » Fri May 26, 2006 6:44 pm
cool.
You really need to fill the holes/area where the lines come out the evap box too.
Splinter
Post
by Splinter » Fri May 26, 2006 7:00 pm
Did that with ductape
You cant see it and its only to stop air getting blown out
206er
Posts: 2590 Joined: Wed Jun 04, 2003 4:24 pm
Post
by 206er » Fri May 26, 2006 10:54 pm
doubt duc tape will last very long once you turn on the heat.
Splinter
Post
by Splinter » Fri May 26, 2006 11:27 pm
The heater core is after that chamber, not before.
BAC5.2
Posts: 9026 Joined: Thu Jan 29, 2004 8:47 pm
Post
by BAC5.2 » Sat May 27, 2006 3:25 pm
Good to know. My AC comes out on Tuesday I rekon.
Manarius
Posts: 1755 Joined: Fri Jul 22, 2005 10:53 pm
Post
by Manarius » Sat May 27, 2006 3:49 pm
My AC stays in as long as I have the car. Need AC in 80F weather. 480 air doesn't work when you're not going 80....
Manarius wrote: The Neo-Cons would call me a defeatist. I'd call me a realist. I'm realistically saying that a snowball has better chances in the blazes of hell than democracy has in Iraq.
THAWA
Posts: 6829 Joined: Thu Aug 21, 2003 7:44 pm
Post
by THAWA » Sun May 28, 2006 1:46 am
I think the actual grommet used in non-AC cars would have been cheaper than buying a tube of silicon sealer.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
Splinter
Post
by Splinter » Sun May 28, 2006 7:37 am
Except that there are no non-ac legacys in canada
even the Ls have AC
THAWA
Post
by THAWA » Sun May 28, 2006 5:40 pm
What about Impreza's?
CCorsair
Posts: 130 Joined: Tue Apr 04, 2006 9:18 am
Post
by CCorsair » Wed Jun 21, 2006 12:30 am
Ok I know i only have Legacy L Wagon but why the heck would you ever wan to take out the AC?
It can't be for mileage as reading on online research showed that you really don't lose that much in gas unless you are really need a tune up or the engine is very bad shape.
and having been with out AC in our old 86 mazda B2000 truck on 106 day...in stop and go.....No way I ever pull the Ac from the wagon.
CC
1990 Subaru Legacy L Wagon AWD.
Splinter
Post
by Splinter » Wed Jun 21, 2006 1:50 am
You take the AC out because:
1. Weight
2. Parasitic drag
3. Engine bay cleanliness
4. Easier to install front mounts
THAWA
Post
by THAWA » Wed Jun 21, 2006 2:54 am
If you live in the valley in cali or socal there's no reason to remove ac. The "benefits" are way less than not getting heat exhaustion.
Splinter
Post
by Splinter » Wed Jun 21, 2006 3:05 am
I live in Canada.
AC actually warms up the inside of the car.
THAWA
Post
by THAWA » Sat Jun 24, 2006 1:54 am
haha
bmxkelowna
Posts: 1047 Joined: Thu Feb 16, 2006 5:00 am
Post
by bmxkelowna » Sat Jun 24, 2006 2:09 am
Splinter wrote: I live in Canada.
you ac must be like 40*c then!
damn 32*c weather today, its too hot to do any thing
