AC Removal - Firewall plug
Splinter
Post by Splinter »
I dont know how obvious this is, but Id thought Id throw it out there.
For those of you who have removed your AC, but left the evaporator in because you didnt have anything to plug the firewall with:
Tada!
Just pull the rubber boot off the evaporator assembly and use some silicon sealer to fill the holes. Works like a charm.
cool.
You really need to fill the holes/area where the lines come out the evap box too.
Splinter
Post by Splinter »
Did that with ductape :P
You cant see it and its only to stop air getting blown out
206er
Post by 206er »
doubt duc tape will last very long once you turn on the heat.
Splinter
Post by Splinter »
The heater core is after that chamber, not before.
Post by BAC5.2 »
Good to know. My AC comes out on Tuesday I rekon.
Manarius
Post by Manarius »
My AC stays in as long as I have the car. Need AC in 80F weather. 480 air doesn't work when you're not going 80....
THAWA
Post by THAWA »
I think the actual grommet used in non-AC cars would have been cheaper than buying a tube of silicon sealer.
Splinter
Post by Splinter »
Except that there are no non-ac legacys in canada
even the Ls have AC
THAWA
Post by THAWA »
What about Impreza's?
CCorsair
Post by CCorsair »
Ok I know i only have Legacy L Wagon but why the heck would you ever wan to take out the AC?
It can't be for mileage as reading on online research showed that you really don't lose that much in gas unless you are really need a tune up or the engine is very bad shape.
and having been with out AC in our old 86 mazda B2000 truck on 106 day...in stop and go.....No way I ever pull the Ac from the wagon.
CC
1990 Subaru Legacy L Wagon AWD.
Splinter
Post by Splinter »
You take the AC out because:
1. Weight
2. Parasitic drag
3. Engine bay cleanliness
4. Easier to install front mounts
THAWA
Post by THAWA »
If you live in the valley in cali or socal there's no reason to remove ac. The "benefits" are way less than not getting heat exhaustion.
Splinter
Post by Splinter »
I live in Canada.
AC actually warms up the inside of the car.
THAWA
Post by THAWA »
haha
bmxkelowna
Post by bmxkelowna »
Splinter wrote:I live in Canada.
you ac must be like 40*c then! :P
damn 32*c weather today, its too hot to do any thing
