Loctite on flywheel bolts?
red
1
50%
blue
0
No votes
never!
1
50%
Total votes: 2
Some sources say to put loctite on the flywheel to crankshaft bolts, others say not to.
I don't want to put the red high temp loctite on, since it says it takes over 500 degrees F to remove it! :shock:
A little bit of the blue stuff maybe? I don't want anything getting loose, but obviously they'll have to come off eventually.
What are you guys using and how has it worked out?
douglas vincent
Post by douglas vincent »
I just used the blue myself for this exact thing.
I have also used red. Long enough breaker bar will break them free later.
NEVER EVER EVER use loctite on those little screws in back though! I know why :(
Matt Monson
Post by Matt Monson »
I've never felt the need. I tighten them to spec and they have never come loose on me...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Radial GT1
Post by Radial GT1 »
if you use any, use the lowest strength locktite you can find. I think it is green. None should be fine, but a little mind assurance wouldn't hurt either.
00 Camry; No wrenchin', just drive. Thank you Japan!
93 Legacy SS 4Eat 96K; All the wrenching I could ask for.
[quote="un-named"]What a man & a woman, and another man with a sheep & a midget want to do is their own business...[/quote]
BAC5.2
Post by BAC5.2 »
Green Loctite is "Sleeve retaining compound"
Not for threaded applications.
Just use blue if you HAVE to use something.
I don't use loctite on them.
I've decided to not use any loctite, just properly torque the bolts.
I actually did that before posting this thread, but I wanted to be sure before I put the transmission back in.:)
Thanks for the replies!
