PCV WTF
boro
PCV WTF
Post by boro »
Can I remove the PCV System and replace with breather filters?
gto7419
Post by gto7419 »
You *CAN* do this, and I have seen pictures using atmospheric filters while dumping the rest of the pcv system.
I dont know why, but the advice I got was to plumb the pcv system correctly and not use filters.
Can anyone else chime in here???
500cc Shifterkart, 125cc Shifterkart, 01 MX5, 93 Legacy Wagon (DIY Turbo)
boro
Post by boro »
I'd really like to know...
kleinkid
Post by kleinkid »
I have two catch cans to use that have two inlets and an outlet with a small vent filter on each one. I don't anticipate any problems.
boro
Post by boro »
Do you mind whipping up some sort of diagram as to how you are going to run this set-up? Apparently Subaru doesnt even know that my car exists...
gto7419
Post by gto7419 »
Basically, he is using a catch can to catch any overflowing oil and then venting to the atmosphere - probably a good alternative...
You have an air/oil line feeding out of the heads for the pcv system - He ran those two line outs into the "line in" of the catch can. On the "line out" of the catch can, he put an atmospheric filter.
Danny
boro
Post by boro »
gto7419 wrote:Basically, he is using a catch can to catch any overflowing oil and then venting to the atmosphere - probably a good alternative...
Danny
understood. now can I just cap the crank case vent at that point?
douglas vincent
Post by douglas vincent »
Run your crank case vent to the catch can as well.
boro
Post by boro »
douglas vincent wrote:Run your crank case vent to the catch can as well.
Yeahm I just found a 3 input tank.
I would not recommend venting to atmosphere, and I would not recommend capping any vent line.
Keeping a slightly vacuum on the crankcase will help the piston rings seal better, and help with evacuating the blow-by gasses.
rallysam
Post by rallysam »
I'm not venting to atmosphere or capping anything (I don't think). I've got the two tubes coming from the crankcase breathers into a T and then into the catch can (The T is visible in the lower right). From there, two tubes come out of the catch can to the intake tubing and to the PCV valve.
I think the connections are all to the stock locations, just with a catch can added in the middle to catch the oil. Hopefully mother nature likes me.
'00 Impr RS - sold
boro
Post by boro »
nice
BAC5.2
Post by BAC5.2 »
Sam's is hooked up correctly. That's the best way to do it, for the reasons that Josh specified.
Venting them all isn't going to destroy anything, but it might increase blowby.
gto7419
Post by gto7419 »
BAC5.2 wrote:Sam's is hooked up correctly. That's the best way to do it, for the reasons that Josh specified.
You mean for the reasons Josh specified :wink:
Thanks for the explanations, definately helps!!!
BAC5.2
Post by BAC5.2 »
Ninja!
boro
Post by boro »
Ok, lets imagine I don't have any of my stock lines...because well, I don't. They are all broken. Would this work?
boro
Post by boro »
any thoughts on this plan?
IronMonkeyL255
Post by IronMonkeyL255 »
Rio Red '91 Legacy SS
boro
Post by boro »
hmmmm, interesting. Thanks.
Due to space constraints I built some inline foam coalescing filters for the valve covers rather then trying to tie into the catch can.
