tps replacement
dirtyhandssubaru555
tps replacement
so i got a good tps on the way, i was told not to mess with takeing the tps off unless you know what u are doing, but it doenst look that difficult. two screws, mark the srcews and the old tps and match up with mark with the new tps. yes or no?
my girlfriend finaly found out that i spent more money and time on my car then her. she was kind pist to say the least.
92ss, tdo4, wrx stage 1 clutch and 9.5 pound flywheel, sti springs, k&n panel filter, desnorkus
86 gl hatchback rip
87 gl10 rip
86 gl hatchback rip
87 gl10 rip
dirtyhandssubaru555
vikash are are you stocking me? lol! i did a search and didnt see much. josh?
86 gl hatchback rip
87 gl10 rip
86 gl hatchback rip
87 gl10 rip
Just trying to help.
Josh is Legacy777.
http://bbs.legacycentral.org/viewtopic. ... 0825#10825
http://bbs.legacycentral.org/viewtopic. ... 5903#65903
http://bbs.legacycentral.org/viewtopic. ... 9095#69095
http://bbs.legacycentral.org/viewtopic. ... 179#191179
http://bbs.legacycentral.org/viewtopic. ... 711#232711
Josh is Legacy777.
dirtyhandssubaru555
so if i don't get any reading from pins one and two on the tps, does that meen its totaly craped out? when i unplug it the car runs just the same. i didn't do any more testing cause i was being lazy last night and didnt want to start a fire in my garage
86 gl hatchback rip
87 gl10 rip
86 gl hatchback rip
87 gl10 rip
Do you get continuity when you move the throttle?
Are you sure you're orienting the TPS correctly, and using the correct pins?
dirtyhandssubaru555
i get nothing at all from pins 1 and 2, thats what my hanes has to start with.
86 gl hatchback rip
87 gl10 rip
86 gl hatchback rip
87 gl10 rip
Did you look at the posts and links in the posts above to see if the info in there matches to Haynes?
