Loss of power
Loss of power
1994 2.2turbo sedan. 146000km.
When I accelerate hard I get a kind of stumbling, loss of power, backfire. Apart from this the car runs like new, I changed the plugs, and wires. Thanks in advance. By the way I'm new to this site.
I'm speeking from what I've read and not from experience, but seafoam is a product that you run through the engine to remove carbon deposits and it also helps with worn piston rings.
I could be wrong, but at least someone eager to correct me might give you an answer.
I will be changing my engine sometime next week so I haven't worried too much about the one that's in there now, which seems to do exactly what you describe. I've searched quite a bit just out of curiousity and seems "hesitation" can be caused by MANY different things. Vaccum leaks, wires + plugs (don't use bosch, get NGKs), coil pack, faulty injector, and the list goes on. If you search a bit maybe you'll find others who have described a problem similar to yours.
-------Jonathan--------
