Loss of power
mtlrover
Loss of power
Post by mtlrover »
1994 2.2turbo sedan. 146000km.
When I accelerate hard I get a kind of stumbling, loss of power, backfire. Apart from this the car runs like new, I changed the plugs, and wires. Thanks in advance. By the way I'm new to this site.
Post by SubaruNation »
seafoam
dscoobydoo
Post by dscoobydoo »
Is the check engine light on?
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
mtlrover
Post by mtlrover »
Excuse my ignorance but I do not understand
mtlrover
Post by mtlrover »
No engine light on.
Canadian Turbo
Post by Canadian Turbo »
I'm speeking from what I've read and not from experience, but seafoam is a product that you run through the engine to remove carbon deposits and it also helps with worn piston rings.
I could be wrong, but at least someone eager to correct me might give you an answer.
I will be changing my engine sometime next week so I haven't worried too much about the one that's in there now, which seems to do exactly what you describe. I've searched quite a bit just out of curiousity and seems "hesitation" can be caused by MANY different things. Vaccum leaks, wires + plugs (don't use bosch, get NGKs), coil pack, faulty injector, and the list goes on. If you search a bit maybe you'll find others who have described a problem similar to yours.
-------Jonathan--------
yeah i said seafoam b/c of potential built up carbon
mtlrover
Post by mtlrover »
Thanks for the responses. The problem seems to have worked itself out. :shock: It runs great, when I hit the gas it gets up and goes like new. Must have been something in the gas, cause it ran perfect after I filled her up. Thanks again.
Canadian Turbo
I bet it will come back!!!!
dont say that :smt075
youll jinx it!
mtlrover
Post by mtlrover »
Problem has not returned car is running great.. :-D
Canadian Turbo
Hahaha knock on wood. Good luck.
Post by 555BCTurbo »
SubaruNation wrote:seafoam
Seafoam doesn't magically fix things like that...it just cleans stuff up a lil bit
duh :wink:
