So I bought these heads... thinking they were 1993 WRX ej20g heads....
But they have different valve covers and are shimless cam over bucket heads...
Here are some pics... My friend David said there was no way they were 93 wrx heads.... He thinks they are ej20k heads.
Thoughts? Comments? Questions?
And I'd rather have these style heads... but I'm just curious what they're from.
They only have the turbo supply lines on the passenger side head... so they are single turbo heads.
No,
That second set is 1993 Legacy turbo Ej20G heads. See the little HLA in the hole off to the side? Those heads have the stub rockers of the 89-93 Legacy heads,
To pull the buckets, just grab one with your fingers and pull it straight out. If that doesn't work, tip it over on it's side. It will fall right out. You will want to remove them before you hot tank them anyways. Otherwise you risk getting water caught in there and having them rust.
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
how can they be the same thing... 93 ej20g WRX... and 93 ej20g WRX.... yet not be the same...
If you are still doubting compare the combustion chambers and the angles of the valves relative to the head gasket mating face.
The new set (the WRX set) have a much more relaxed valve angle and a combustion chamber that is a good +/-10cc smaller because the roof doesn't rise as high.
The old set (the Legacy set) has a really steep valve angle and pent roof. It's a giant 57cc combustion chamber.
If you compare the little details you will see that there are significant differences between the heads.
Suby Hai!
So should I be able to pull more power out of the WRX ones?
I'm guessing a higher Comp Ratio than the Legacy heads...
