tickey valve
lucas
tickey valve
Post by lucas »
i just ran half a can of sea foam through my crank case, when i changed the oil after about 500 miles i noticed that on the drivers side of the motor im getting quite a bit of valve chatter. Do you think this could be a sign of something more serious or should i try to run an engine cleaner again, or some kind of sticky valve cleaner.
A1Fiddler
Post by A1Fiddler »
I'm no expert, but I'd say try changing the oil again. That cleared up my valve ticking.
'92 Legacy Sport Sedan - EJ22T, 4EAT, AWD - Snorkle Delete, Custom Grounding, 3" Catless TBE.
