tickey valve
tickey valve
i just ran half a can of sea foam through my crank case, when i changed the oil after about 500 miles i noticed that on the drivers side of the motor im getting quite a bit of valve chatter. Do you think this could be a sign of something more serious or should i try to run an engine cleaner again, or some kind of sticky valve cleaner.
