Knock Sensor Problerm
Locked
formview
Post by formview »
My knock sensor appears to be failing. My check engine light blinks
on for a second or two every few days. When I check the code it
indicates a failure with the Knock Sensor.
I looked up the procedure for replacing it in my Haynes Repair Manual
(I know it's not the best), and it looks like it's a really big pain
to replace (remove intake manifold to get to it). I was wondering if
is really that hard? I guess the problem is that I don't know what
the sensor looks like. Is it located on the driver side rear of the
engine, and has one wire coming out of it with a bolt in the middle
of it (mine says 960 Japan A53-000 R00 on it)? Also the manual says
you have to drain the water out of the engine before replacing it.
I have a 1990 non-turbo Legacy with an automatic transmission.
Thanks for you help and advise.
Free $5 Love Reading
Risk Free!
http://us.click.yahoo.com/3PCXaC/PfREAA ... /XoTolB/TM
Josh Colombo
Post by Josh Colombo »
Haynes is full of shit on their procedure. All you need is a socket and
a long extension. Unscrew for the block, unplug from the electrical
connector, and pull it out, and replace with new one.
Josh Colombo
Josh@surrealmirage.com <mailto:Josh@surrealmirage.com>
of beats and rhythm" - ME
-----Original Message-----
Sent: Saturday, June 22, 2002 11:43 PM
Subject: [BC-BFLegacyWorks] Knock Sensor Problerm
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Risk Free!
Rod
Post by Rod »
as Josh mentioned, it's 'easy as' to replace, especially on a non turbo engine. I recently replaced mine (RS Liberty turbo) and had to remove intercooler to get to it. Simply unplug wire, use socket on extension and then R & R...
My car now boosts better and my economy is also better.. It has been an intermittent problem for over 6 months. Finally had enough of the constant error code coming up ( every 4 days ) and replaced it- should of done it heaps earlier.
cheers, Rod...in oz
----- Original Message -----
Sent: Sunday, June 23, 2002 3:19 PM
Subject: RE: [BC-BFLegacyWorks] Knock Sensor Problerm
Josh Colombo
formview
Post by formview »
Thanks Josh/Rod for the reply. I was wondering, from what I
described, did I find it? Also, I guess I don't have to worry about
draining the water from the system.
Maybe I should invest in a Subaru Shop manual?
Thanks for your help!
> cheers, Rod...in oz
> From: Josh Colombo
> To: BC-BFLegacyWorks@y...
socket and
electrical
> Josh Colombo
> Josh@s... <mailto:Josh@s...>
> From: formview [mailto:yahoo@m...]
blinks
Manual
pain
if
what
the
middle
says
> BC-BFLegacyWorks-unsubscribe@e...
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
Risk Free!
adriatic75
Post by adriatic75 »
If you live near a winger subaru shop they can do it for $20, that's
if you can't be bothered doing it yourself.
to
of
> > cheers, Rod...in oz
> > From: Josh Colombo
> socket and
> electrical
> > Josh Colombo
> blinks
> Manual
> pain
wondering
> if
> what
> the
> middle
> says
it.
> Service.
Risk Free!
formview
Post by formview »
Must be a pretty easy job if it's only $20. Thanks for the info.
that's
about
non
> to
on
has
enough
> of
it-
> > > cheers, Rod...in oz
> > > From: Josh Colombo
> > socket and
> > electrical
> > > Josh Colombo
> > blinks
it
Repair
> > Manual
big
> > pain
> wondering
> > if
> > what
of
> > the
> > middle
manual
> > says
replacing
> it.
> > Service.
Risk Free!
Locked
