91 Legacy Wagon Front Passenger side Power Window issue....
Front Passenger side Power Window rolls down but does not roll up. removed power regulator and tested on rear door connection and regulator works both up and down. Swapped switches and still no luck with front connection. Could it be a wiring issue or ground somewhere?
Welcome to the BBS. It could be a wiring issue. The wiring is all tied back to the driver's switch. So you could have an issue with the driver's switch which could be causing the problem, or possibly wiring to the driver's switch.
Here are the wiring diagrams for the 90 legacy. They should be the same for the 91 Legacy. Take a look at the diagram for the power windows, and it may make some more sense how they have these things wired.
http://main.experiencetherave.com/subar ... agrams.zip
