Removing Drive axle 32mm bolt?
aesalinas45
Any suggestions on getting these bolts broke loose? Went through three 24" breaker bars.
Are you talking about the axle nuts? You need to make sure the little section of the nut that is pounded into that gap in the axle to hold it in place is pounded back out. Then use a quality breaker bar with a 3-4 foot pipe. Works every time for me. I thought it was going to break the breaker bar last time but it finally gave.
aesalinas45
My impact took it off pretty easy with the edge tapped in.kimokalihi wrote:Are you talking about the axle nuts? You need to make sure the little section of the nut that is pounded into that gap in the axle to hold it in place is pounded back out. Then use a quality breaker bar with a 3-4 foot pipe. Works every time for me. I thought it was going to break the breaker bar last time but it finally gave.
Yeah I guess that would work too. I wouldn't know, I don't use power tools. I gots to be creative when I work on my car lol.
