Engine Question???
Engine Question???
Okay so the original owner of my car screwed the crap out of the engine supposedly he kept filling the radiator with water instead of antifreeze and it rusted and corroded the crap out of all the water ways to the point that the water was getting into the engine needless to say it was finish! so after searching far and wide i finally found an engine with low miles but it was only an EJ20 but i said whatever and dropped it in! so my question is what am i loosing out on??? is it a lot weaker then the EJ22 how dose it compare??? should i keep looking 4 a 22 or just leave it in??? whats your opinion?? thanks
1992 Legacy L (AWD )(5MT)[2.5RS Trans] EJ22T Swap in Progress
Re: Engine Question???
Can you provide a little more details. Is this a turbo or non-turbo car? Was the EJ20 from a non-turbo car as well?
yes its all N/A the EJ20 as well as my car
so how much am i loosing out on??? would it be worth looking 4 an EJ22 or should i just keep the EJ20?
you lose .2, if its a DD leave it.
I'd agree with Nico. Just leave it.
