Done some searching and haven't been able to come up with a definitive answer. When rebuilding a 22t block with forged pistons and rods, what is the size of 2.2t rods? When looking at eagle rods they list the 1.8, 2.0 and 2.2 as the same Part # and length so I am assuming that those engines all used the same rod lengths. Am I correct?
-Logan
22t connecting rod length
VF43 custom FMIC APEXI intake Invidia 3" TBE JDM Ver. 4 RA STi trans (4.44) SPT short shifter rear LSD WRX rear axels coilover suspension JDM 4-pot front brakes drilled slotted rottors Greddy EBC tuned 20G ECU sti 550cc injectors Jecs MAF walbro 255
Re: 22t connecting rod length
I know for sure the 2.0L WRX and 2.5L STi/WRX rods are the same length as 22t rods...5.137" (130.5mm)
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
16 WRX | 6mt | fa20
These are the rods you want. There's only one
http://main.experiencetherave.com/subar ... G_1945.JPG
Haha, those are what, $400+ for the 4? STI rods are cheap and stronger than what 99% of us will ever need on these engines.Legacy777 wrote:These are the rods you want. There's only one
He was specifically asking what the Eagle part # was....which is why I posted that.....
