1. Had a Crank, No Start (No Spark) Issue.
2. Connected Black 'Code Plugs' together and read codes.
3. Undid 'Code Plugs'.
4. Now will not crank (Gives triple Click/Tick Sound on Ignition Key in turned to Start Position)?
Note: The 'Code Plugs' were *PAIN in the Arse* to get to reach each other... had to push harness around
Will also check fuses/relays in daylight - but any ideas on 3 Click/Tick Sound and no Crank?!
ANY/ALL ideas appreciated; Thanks!,
#89
