From Crank, No Start to No Crank?!
Post by #89 »
Hi Team,
1. Had a Crank, No Start (No Spark) Issue.
2. Connected Black 'Code Plugs' together and read codes.
3. Undid 'Code Plugs'.
4. Now will not crank (Gives triple Click/Tick Sound on Ignition Key in turned to Start Position)?
Note: The 'Code Plugs' were *PAIN in the Arse* to get to reach each other... had to push harness around :? ... maybe pinched harness/wire(s)?!
Will also check fuses/relays in daylight - but any ideas on 3 Click/Tick Sound and no Crank?!
ANY/ALL ideas appreciated; Thanks!,
#89
Re: From Crank, No Start to No Crank?!
Were any codes present?
Are you sure your battery is good and charged up? You may want to try a set of jumper cables or put it on the charger.
#89
Post by #89 »
Hey thx for response...
Yep. Battery charged, Boost Pack attached... still no crank and 3 repeated click/tick sounds.
Was cranking fine (but no spark) BEFORE connecting black code read harnesses.
Codes 11 (Crank Angle) & 35 (Purge Can) showed up.
#89
I'd suggest getting a big socket on the crank bolt and turn the engine over by hand a few turns, and then try to crank it again.
If it doesn't crank and your battery is good, then the problem is likely the starter (most likely the solenoid contacts) or the battery cables.
