http://motors.shop.ebay.com/i.html?_nkw ... rksid=m270
How different are the oil pumps year to year. I have two, one I can't get to spin and the other seems ok but it's old and I feel better with a new one. Auto zone, and oreilly's do not carry the oil pump. Will this one work need it by Friday.
Oil pump
RckyMtnLegacy
Oil pump
1990 2.2l Legacy--RIP
Keeping the Legacy's Legacy
Official Subaru Ambassador
Re: Oil pump
Well your car came with a shimmed 10mm oil pump, same thing as the STI uses. That one I'd guess is either a standard 9 or 10mm pump. It'll work, but an STI one would be better.
RckyMtnLegacy
Re: Oil pump
Where is the best place to find one or check if mine is good
Re: Oil pump
NASIOC or the dealership but I buy all my OEM parts from 1stsubaruparts.com which usually has the best prices.
RckyMtnLegacy
Re: Oil pump
Ok I will look. So basically all will bolt on the insides are different? So a 2004 sti oil pump will work?
Re: Oil pump
Yes. You'll find that the STI oil pump part number has replaced the SS one.RckyMtnLegacy wrote:Ok I will look. So basically all will bolt on the insides are different? So a 2004 sti oil pump will work?
Re: Oil pump
Any EJ oil/water pump will fit. But go with the STI one for better performance.
