I did... Looks green on top,maybe orange ish towards the bottom, i really cant tell. And ya! Its like two face, from one side it looks like all my coolant is green and on one end all orange
I had a couple buddies say its usually a sign of rust with the rad or something but all of that is new for my car... Do I risk engine damage running with it like this?
I would flush the system and put fresh coolant in. As long as it is not oil you will be fine. Oil will cause the rubber hoses to swell and weaken. I drove around with a leaking water oil cooler and had no real effects on the engine besides the rubber hoses going bad.
91 black SS 5 speed (Canadian).... Closed deck EJ20G, fully built, V5/6 sti ra drivetrain, haltech stand-alone
93 silver TW 5 speed... rebuilt 22T with 20G heads, wrx ra drivetrain, otherwise stock.
73 kazen red VW bus riviera camper
Thanks for quick response and good advice! I will be flushing it next weekend. Interested to see if there will be more orange in the rest of the system. Kinda interesting that the orange part in my res is next to battery
