low idle
208ss
low idle
Post by 208ss »
So after my car warms up at idle my car is running at 17/1-19/1 afr and has low idle around > 500 rpm.
What could be the cause?
And go...
1991 subaru legacy sport sedan
bcmaxx
Re: low idle
Post by bcmaxx »
208ss wrote:So after my car warms up at idle my car is running at 17/1-19/1 afr and has low idle around > 500 rpm.
And go...
What is your vacuum sitting at?
wtdash
Re: low idle
Post by wtdash »
Vacuum leak.
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
208ss
Re: low idle
Post by 208ss »
Boost Guage is at 18 vac
robertpaige
Re: low idle
Post by robertpaige »
Should be at 20ish. At 18 I would assume you have vacuum leaks. Do a smoke test
