So after my car warms up at idle my car is running at 17/1-19/1 afr and has low idle around > 500 rpm.
What could be the cause?
And go...
low idle
Re: low idle
What is your vacuum sitting at?208ss wrote:So after my car warms up at idle my car is running at 17/1-19/1 afr and has low idle around > 500 rpm.
And go...
Re: low idle
Vacuum leak.
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
robertpaige
Re: low idle
Should be at 20ish. At 18 I would assume you have vacuum leaks. Do a smoke test
