http://qsr.divahost.net/MorgieSnowDrift2003-03.wmv
Snow Video - Updated -
morgie
here is the "little" video i made for fun, hope you like it !
morgie
'98 4Runner V6 Manual 4x4.
morgie
yeah it was a CRAP camera a friend borowed/boroed ... focus is bah when lights shines into the lenses...
nyway, hey, what about another short one ?
--- Edit : Full Vid Soon
morgie
Morgie, I have more vids of you than anyone else
. I always show them to people and say "That's my car, only it's someone else's
." in an effort to show off what she looks like to non-locals. I also like to say to myself "wow, my car can do that?!"
IggDawg is cool.
-IggDawg
1994 Barcelona Red SVX LSi.
1990 CRX Si (for sale)
I know a little about Subarus.
-IggDawg
Damn! that was a trip
. good sync with the music too! 2 questions:
1) what kind of tires you running?
2) what are you using to get sideways? ebrake, brakes, loud pedal?
you get your ass out so easily, and recover it with even less difficulty. I could really use a few pointers. I'm alright, but I need some technique help and I don't have enough time to practice
. yesterday I was playing around and I was having way too much of a hard time keeping from plowing. last season I had Arctic Alpins, and this season I'm on Michelin M2s. the M2s are nicer in the dry, but I think the arctic alpins were a superior tire in the snow.
IggDawg is cool.
-IggDawg
-IggDawg
eastbaysubaru
You don't really need the hand brake to get the tail out in loose situations. The brake pedal usually does the trick. You've just got to figure out how to transfer the weight accordingly. Perhaps a little scandinavian flick? Combine that with a little brake pedal and the tail should come right out. RallyX's help a lot for figuring out how to pivot the car on the front.
-Brian
-Brian
'04 PSM FXT
- quasi-mod-o
Isn't it ironic that this is topic #666, which shows such devilish antics behind the wheel?
Sorry, I'm bored...
Sorry, I'm bored...
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
my problem is I'm used to usign the loud pedal to get the rear out, and invariably I end up getting sideways too quickly, and going too fast. I think I just need to work on timing and anticipation. I've been to a rally-X or 2, but I need to practice way more.eastbaysubaru wrote:You don't really need the hand brake to get the tail out in loose situations. The brake pedal usually does the trick. You've just got to figure out how to transfer the weight accordingly. Perhaps a little scandinavian flick? Combine that with a little brake pedal and the tail should come right out. RallyX's help a lot for figuring out how to pivot the car on the front.
-Brian
IggDawg is cool.
-IggDawg
-IggDawg
morgie
Igg : You're doing what a lot of people are doing wrong
(and i always wanted to write a "how-to" for that
) You get your rear-end sideways with the _BRAKE_ (or releasing the gaz) , and you keep it sideways/control everything with the gaz or clutch. Sometimes, clutch also helps for getting the rear turn more quickly. also , ABS -> OFF. ABS will mess all your weight transfer you are so hardly trying to do in the snow
At 1:39 in the vid, you can see i'm on the brakes for a while and then back on the gas . But that was only for the "show" .. to have a lower-radius turn, i should have used the "pendulum" technique. I use that a lot in the inside-car / darker shots (3:30). This throws the rear end of the car into the turn, and you barely just have to floor the gaz and wait till it ends
in short, the secret is Practicing, and practicing a lot
(and watching some japaneese drifting videos for the techniques
ah and my tires are 2 years old (3rd this year) Nokian Hakkapeliitta 1, 195-65-15 they will ruffly be good for another winter.
morgie
Aaron's ej22t
nice video morgie as well as your other tarmac drifting videos.
i need a camera to film my stuff, i go drifting on dirt/gravel all the time and do lots of winter drifting in snow too!
i don't like to drift or even attempt it on tarmac, whether it is dry of wet. it feels weird to me. i like how on snow, it is so graceful and smooth. if i can film some stuff, i will try and make a short 1 minute clip of drifting.
92 Legacy Turbo \ 5MT \ Silver
