Error code 24...
BAC5.2 wrote:Yea, I don't know how to do that, lol.
Page 74, section 2-7
BAC5.2
Post by BAC5.2 »
Well, it's futile, this thing is FUBAR.
Looks like I'll be going to the dealer to spend $362 for a new IAC valve. I should bend over and walk in backwards to make their job a little easier.
junkyard.......
legacy92ej22t
Post by legacy92ej22t »
It's going to be very hard to find an IAC valve for a turbo in a junkyard. Most yards want to sell the engine whole and not part it out. The IAC will definitely be considered an engine component.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
THAWA
Post by THAWA »
the hell with those guys. Don't give them any business!
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
ok.....then these guys www.superrupair.com
BAC5.2
Post by BAC5.2 »
To late, went to the dealership. $400 and it'll be there tomorrow or tuesday :(
free5ty1e
Post by free5ty1e »
I've just got to say, brake parts cleaner is the best friggin cleaning product known to man. If you can't clean it with brake part cleaner, you can't clean it. :D
Although, I woulnd't recommend cleaning anything like your teeth with that stuff. Although theoretically it would work quite well, I'm pretty sure there'd be some negative side effects, other than the taste. Which I'd imagine would not be all that pleasant.
OK back to the post topic. Where's this bitch located? I see the pic above but that's not in an engine compartment, it's on newspaper.
-Chris
91SS 4EAT stock, 200k mi
BAC5.2
Post by BAC5.2 »
Look at your engine from the front of the car.
Look at the intake runner for the 3rd cylinder (I think that's #3). It's the one on the passenger side closest to the firewall.
There is a bigass black hose coming off of the pre-turbo resonator.
That hose leads to the IAC valve. It sits right off of the plenum facing the passenger side strut tower. It's got an electrical connector on top of it and a hose feeding it from an angle.
free5ty1e
Post by free5ty1e »
Ahh I see the light... thanks BAC... my idle's fine right now but at least I know where to look if it gives me trouble.
-Chris
Rhinoculips
Post by Rhinoculips »
started a new thread.....port removed
log1call
Post by log1call »
The idle control may be fine, there may be an air leak which could cause the no boost and the irregular idling.
The problem with the O2 code too may not ne the sensor but something else that effects fuel mixture.
Those codes are just an aid to diagnosis and quite often don't mean the indicated item is faulty.
